Ana içeriğe geç
Motorola Razr V3c Face-Screen Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Motorola Razr V3c Face-Screen Replacement, Face-Screen: adım 1, 1 resimden 1.
    • Clear a table or desk to use as a workspace. You will need a container to place small screws as they will be used in reassembly.
  2. Motorola Razr V3c Face-Screen Replacement: adım 2, 1 resimden 1.
    • Open the phone's face.
  3. Motorola Razr V3c Face-Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the four screws located around the face plate using a 1.5mm Hex tool.
  4. Motorola Razr V3c Face-Screen Replacement: adım 4, 1 resimden 1.
    • After removing the screws, use a flat surfaced tool to take the face-screen off.
  5. Motorola Razr V3c Face-Screen Replacement: adım 5, 1 resimden 1.
    • Use this step as a checkpoint. Once the face-screen cover is off, the workspace should resemble this step’s picture.
  6. Motorola Razr V3c Face-Screen Replacement: adım 6, 1 resimden 1.
    • Carefully remove the face-screen using your fingers.
  7. Motorola Razr V3c Face-Screen Replacement: adım 7, 1 resimden 1.
    • You may now carefully install a functioning face-screen.
  8. Motorola Razr V3c Face-Screen Replacement: adım 8, 1 resimden 1.
    • After securing the face-screen into the casing, place the face screen cover back on.
  9. Motorola Razr V3c Face-Screen Replacement: adım 9, 1 resimden 1.
    • Screw in the four corner screws. After completion of this step, your phone should function properly. Enjoy!
Sonuç
Enjoy your newly inserted face-screen.
Nigel
133 İtibar
2 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-5, Zipperian Fall 2011 Cuesta, Team 1-5, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G5
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,818
