Ana içeriğe geç
Giriş
The purpose of this guide is to help you replace your keypad cover.
Parçalar
Hiçbir parça belirtilmedi.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Remove the two T6 screws on the back of the phone.
    • Remove the two T6 screws on the back of the phone.
  4. Use the plastic opening tool to pop the bottom part of the back case out.
    • Use the plastic opening tool to pop the bottom part of the back case out.
    • The back case is connected to the phone with a ribbon cable; take care not to pull too hard or violently on the cable.
  5. Gently pull back case out and lay it over to the side.
    • Gently pull back case out and lay it over to the side.
    • Now pull up on the cable attaching the back case to the phone body to separate the two parts. Lay the back case aside for now.
  6. Remove the two T6 screws securing the plastic speaker cover to the phone.
    • Remove the two T6 screws securing the plastic speaker cover to the phone.
  7. Pull off the lower front casing.
    • Pull off the lower front casing.
    • The metal shield will come off when the lower front casing is removed. Make sure to replace this when reassembling the lower bottom casing.
  8. Pull the silver plastic cover down away from the rest of the phone.
    • Pull the silver plastic cover down away from the rest of the phone.
  9. Push the metal tabs along the perimeter of the device through towards the keyboard with your fingers.
    • Push the metal tabs along the perimeter of the device through towards the keyboard with your fingers.
  10. Gently lift up on the keypad with the plastic opening tool while being careful not to bend the thin metal portion lining the keypad.
    • Gently lift up on the keypad with the plastic opening tool while being careful not to bend the thin metal portion lining the keypad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
krisko
95 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 6,812
