Ana içeriğe geç
Motorola Razr V3c Lower Casing (CDMA) Replacement
Neye ihtiyacın var
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 2. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 3.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 2, 2 resimden 1. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): adım 3, 1 resimden 1.
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 5, 1 resimden 1.
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 6, 2 resimden 1. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 6, 2 resimden 2.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 7, 2 resimden 1. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 7, 2 resimden 2.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 8, 1 resimden 1.
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): adım 9, 2 resimden 1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): adım 9, 2 resimden 2.
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): adım 10, 1 resimden 1.
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: adım 11, 1 resimden 1.
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Sonuç
Bir başkası bu kılavuzu tamamladı.
krisko
104 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 6,240
