Giriş
The purpose of this repair guide is to show how to replace the lower outer casing.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Unscrew the two screws in the back using the T6.
    • Unscrew the two screws in the back using the T6.
  4. Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. Peel off the connector between the motherboard and the body of the phone.
    • Peel off the connector between the motherboard and the body of the phone.
  7. Pull out the two black rubber covers using tweezers. The second rubber cover is much harder to get out.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  8. Pull out the white plastic cover by unclipping the two plastic pieces shown. Pull out the white plastic cover by unclipping the two plastic pieces shown.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  9. Pull out the speaker.
    • Pull out the speaker.
  10. Pull out the motherboard. You may also now replace the bottom lower casing
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  11. Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  12. Pull off and replace the lower front casing
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Sonuç
Bir başkası bu kılavuzu tamamladı.
krisko
95 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 6,045
