Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Motorola Razr V3c Motherboard (CDMA) Replacement
Neye ihtiyacın var
  1. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 1. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 2. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): adım 1, 3 resimden 3.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 2, 2 resimden 1. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Motherboard (CDMA) Replacement, Speaker (CDMA): adım 3, 1 resimden 1.
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 5, 1 resimden 1.
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 6, 2 resimden 1. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 6, 2 resimden 2.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 7, 2 resimden 1. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 7, 2 resimden 2.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Motherboard (CDMA) Replacement: adım 8, 1 resimden 1.
    • Pull out the speaker.
  9. Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): adım 9, 2 resimden 1. Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): adım 9, 2 resimden 2.
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Joshua Ruehlig
506 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 6,690
