Ana içeriğe geç
Motorola Razr V3m Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Razr V3m Motherboard Replacement, Battery: adım 1, 2 resimden 1. Motorola Razr V3m Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Motherboard Replacement: adım 2, 2 resimden 1. Motorola Razr V3m Motherboard Replacement: adım 2, 2 resimden 2.
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Motherboard Replacement, SIM Card: adım 3, 2 resimden 1. Motorola Razr V3m Motherboard Replacement, SIM Card: adım 3, 2 resimden 2.
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Motherboard Replacement, Antenna: adım 4, 2 resimden 1. Motorola Razr V3m Motherboard Replacement, Antenna: adım 4, 2 resimden 2.
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully use a plastic opening tool to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Motherboard Replacement: adım 6, 2 resimden 1. Motorola Razr V3m Motherboard Replacement: adım 6, 2 resimden 2.
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Motherboard Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
  8. Motorola Razr V3m Motherboard Replacement: adım 8, 2 resimden 1. Motorola Razr V3m Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to pry the edge of the antenna away from back panel.
    • The antenna may be fastened with two grey clips on either side. If this is so, unfasten two plastic clips located on the edge of the antenna.
    • Lift antenna away from back panel.
  9. Motorola Razr V3m Motherboard Replacement, Speaker: adım 9, 1 resimden 1.
    • The Speaker is the round piece located beneath the antenna.
    • Use tweezers to remove the speaker.
  10. Motorola Razr V3m Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • The Motherboard is the large green and silver piece located in the back panel.
    • Use tweezers to remove motherboard away from the back panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Simcock
731 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 535
