Ana içeriğe geç
Motorola Rival Keyboard Replacement
Neye ihtiyacın var
  1. Motorola Rival Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Motorola Rival Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Motorola Rival Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Locate the lever to release the cover of the device.
    • Push down on lever and pull the cover away from the device.
  2. Motorola Rival Keyboard Replacement: adım 2, 2 resimden 1. Motorola Rival Keyboard Replacement: adım 2, 2 resimden 2.
    • Locate the battery on the back of the phone.
    • Remove the battery from the phone.
  3. Motorola Rival Keyboard Replacement: adım 3, 2 resimden 1. Motorola Rival Keyboard Replacement: adım 3, 2 resimden 2.
    • Take out the 6 screws on the corners of the phone in order to get inside of the phone.
  4. Motorola Rival Keyboard Replacement: adım 4, 2 resimden 1. Motorola Rival Keyboard Replacement: adım 4, 2 resimden 2.
    • Using the pry tool gently remove the back piece of the phone from the front piece.
  5. Motorola Rival Keyboard Replacement: adım 5, 1 resimden 1.
    • Using the pry tool remove the camera button from the phone.
  6. Motorola Rival Keyboard Replacement: adım 6, 1 resimden 1.
    • Using the pry tool, remove the lock/mute button.
  7. Motorola Rival Keyboard Replacement: adım 7, 1 resimden 1.
    • Using the pry, remove the volume buttons.
  8. Motorola Rival Keyboard Replacement: adım 8, 2 resimden 1. Motorola Rival Keyboard Replacement: adım 8, 2 resimden 2.
    • Using a screw driver, locate and remove the screws that connect the keyboard to the mother board.
  9. Motorola Rival Keyboard Replacement: adım 9, 3 resimden 1. Motorola Rival Keyboard Replacement: adım 9, 3 resimden 2. Motorola Rival Keyboard Replacement: adım 9, 3 resimden 3.
    • With the pry tool, gently lift the mother board out of the frame.
    • Be sure to be gentle when lifting it up.
  10. Motorola Rival Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the keyboard from the frame.
    • Replace with new keyboard
Sonuç
Sekani Paul
231 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-8, Bhusal Fall 2015 UMass Dartmouth, Team 1-8, Bhusal Fall 2015 üyesi
UMASSD-BHUSAL-F15S1G8
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 212
