Ana içeriğe geç
Motorola SLVR L9 Antenna Cover Replacement
Neye ihtiyacın var
  1. Motorola SLVR L9 Antenna Cover Replacement, Battery: adım 1, 2 resimden 1. Motorola SLVR L9 Antenna Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Antenna Cover Replacement: adım 2, 3 resimden 1. Motorola SLVR L9 Antenna Cover Replacement: adım 2, 3 resimden 2. Motorola SLVR L9 Antenna Cover Replacement: adım 2, 3 resimden 3.
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Antenna Cover Replacement: adım 3, 3 resimden 1. Motorola SLVR L9 Antenna Cover Replacement: adım 3, 3 resimden 2. Motorola SLVR L9 Antenna Cover Replacement: adım 3, 3 resimden 3.
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: adım 4, 3 resimden 1. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: adım 4, 3 resimden 2. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: adım 4, 3 resimden 3.
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
Sonuç
Eric Lopez
201 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 135
