Ana içeriğe geç
Motorola SLVR L9 Camera Lens Cover Replacement
Neye ihtiyacın var
  1. Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: adım 1, 2 resimden 1. Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: adım 1, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola SLVR L9 Camera Lens Cover Replacement: adım 2, 3 resimden 1. Motorola SLVR L9 Camera Lens Cover Replacement: adım 2, 3 resimden 2. Motorola SLVR L9 Camera Lens Cover Replacement: adım 2, 3 resimden 3.
    • Press down on the battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola SLVR L9 Camera Lens Cover Replacement: adım 3, 1 resimden 1.
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
    FixBot'a Sor
    Yorum Ekle
  4. Motorola SLVR L9 Camera Lens Cover Replacement: adım 4, 2 resimden 1. Motorola SLVR L9 Camera Lens Cover Replacement: adım 4, 2 resimden 2.
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tayler Blanchard
258 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 438
