Ana içeriğe geç
Motorola SLVR L9 Front Panel Replacement
Neye ihtiyacın var
  1. Motorola SLVR L9 Front Panel Replacement, Battery: adım 1, 2 resimden 1. Motorola SLVR L9 Front Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Front Panel Replacement: adım 2, 3 resimden 1. Motorola SLVR L9 Front Panel Replacement: adım 2, 3 resimden 2. Motorola SLVR L9 Front Panel Replacement: adım 2, 3 resimden 3.
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Front Panel Replacement: adım 3, 3 resimden 1. Motorola SLVR L9 Front Panel Replacement: adım 3, 3 resimden 2. Motorola SLVR L9 Front Panel Replacement: adım 3, 3 resimden 3.
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: adım 4, 2 resimden 1. Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: adım 4, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing towards you.
  5. Motorola SLVR L9 Front Panel Replacement: adım 5, 3 resimden 1. Motorola SLVR L9 Front Panel Replacement: adım 5, 3 resimden 2. Motorola SLVR L9 Front Panel Replacement: adım 5, 3 resimden 3.
    • Press down on the battery cover latch located at the top of the phone.
  6. Motorola SLVR L9 Front Panel Replacement: adım 6, 1 resimden 1.
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  7. Motorola SLVR L9 Front Panel Replacement: adım 7, 2 resimden 1. Motorola SLVR L9 Front Panel Replacement: adım 7, 2 resimden 2.
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
  8. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: adım 8, 3 resimden 1. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: adım 8, 3 resimden 2. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: adım 8, 3 resimden 3.
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
  9. Motorola SLVR L9 Front Panel Replacement, Front Panel: adım 9, 1 resimden 1.
    • Use a screwdriver with a T6 Torx screwdriver head to turn the screw counter-clockwise (left).
  10. Motorola SLVR L9 Front Panel Replacement: adım 10, 3 resimden 1. Motorola SLVR L9 Front Panel Replacement: adım 10, 3 resimden 2. Motorola SLVR L9 Front Panel Replacement: adım 10, 3 resimden 3.
    • Using the grooves around the edge of the phone, gently pull the front panel away from the phone until it is fully removed from the device.
Sonuç
Ivan Sarabia
104 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 163
