Ana içeriğe geç
Motorola SLVR L9 Keypad Replacement
Neye ihtiyacın var
  1. Motorola SLVR L9 Keypad Replacement, Battery: adım 1, 2 resimden 1. Motorola SLVR L9 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola SLVR L9 Keypad Replacement: adım 2, 3 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 2, 3 resimden 2. Motorola SLVR L9 Keypad Replacement: adım 2, 3 resimden 3.
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola SLVR L9 Keypad Replacement: adım 3, 3 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 3, 3 resimden 2. Motorola SLVR L9 Keypad Replacement: adım 3, 3 resimden 3.
    • To remove the battery, pull the battery up from the bottom center.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: adım 4, 2 resimden 1. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: adım 4, 2 resimden 2.
    • Turn the phone over so that the back of the phone is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola SLVR L9 Keypad Replacement: adım 5, 3 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 5, 3 resimden 2. Motorola SLVR L9 Keypad Replacement: adım 5, 3 resimden 3.
    • Press down on the battery cover latch located at the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola SLVR L9 Keypad Replacement: adım 6, 1 resimden 1.
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
    FixBot'a Sor
    Yorum Ekle
  7. Motorola SLVR L9 Keypad Replacement: adım 7, 2 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 7, 2 resimden 2.
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola SLVR L9 Keypad Replacement, Antenna Cover: adım 8, 3 resimden 1. Motorola SLVR L9 Keypad Replacement, Antenna Cover: adım 8, 3 resimden 2. Motorola SLVR L9 Keypad Replacement, Antenna Cover: adım 8, 3 resimden 3.
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola SLVR L9 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
    • Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
    FixBot'a Sor
    Yorum Ekle
  10. Motorola SLVR L9 Keypad Replacement: adım 10, 3 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 10, 3 resimden 2. Motorola SLVR L9 Keypad Replacement: adım 10, 3 resimden 3.
    • Using the grooves around the edge of the phone, gently pull the front plate away from the phone until it is fully removed from the device.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola SLVR L9 Keypad Replacement: adım 11, 2 resimden 1. Motorola SLVR L9 Keypad Replacement: adım 11, 2 resimden 2.
    • Lift the keypad up from the front plate to remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eric Lopez
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Sam Houston State, Team 1-5, Blackburne Fall 2015 Sam Houston State, Team 1-5, Blackburne Fall 2015 üyesi
SHSU-BLACKBURNE-F15S1G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 596
