Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Parçalar
Hiçbir parça belirtilmedi.
  1. Push down on the black tab located at the top center of the Motorola phone.
    • Push down on the black tab located at the top center of the Motorola phone.
  2. Remove the battery by pulling the battery from the top center.
    • Remove the battery by pulling the battery from the top center.
  3. Remove the four (4) T6 Torx screws from the back of the metal back plate.
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  4. Insert the flat end of a spudger and pry the metal cover up off the phone. Insert the flat end of a spudger and pry the metal cover up off the phone.
    • Insert the flat end of a spudger and pry the metal cover up off the phone.
  5. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  6. Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard. De-route the antenna cable by pulling it out.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
Sonuç
Jorge Trujillo
499 İtibar
4 adet Kılavuz yazıldı
Takım
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G1
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,742
