Giriş
Has your keypad stopped responding due to debris build-up? This guide will show you how to remove the keypad.
Neye ihtiyacın var
At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
The antenna will pull out with little effort.
On the back of the phone, locate the tab with the down arrow.
Using your finger, press the tab and slide the back cover down to release it from the phone.
Locate the three screws that secure the back battery housing to the phone.
Use a Torx T6 screwdriver to unscrew the screws and then remove them with your fingers.
