Giriş
The circuit board is the connecting point of all components in the radio. If the circuit board is malfunctioning, the radio will not function until the circuit board is replaced. Follow the steps below to properly replace the circuit board of the radio.
Neye ihtiyacın var
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
Bir başkası bu kılavuzu tamamladı.
