Ana içeriğe geç
Motorola Triumph Speaker Replacement
Neye ihtiyacın var
  1. Motorola Triumph Speaker Replacement, Battery: adım 1, 3 resimden 1. Motorola Triumph Speaker Replacement, Battery: adım 1, 3 resimden 2. Motorola Triumph Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the back cover down.
    • Lift the back cover up.
    • Pry the battery out with the spudger
  2. Motorola Triumph Speaker Replacement: adım 2, 1 resimden 1.
    • Gently pry out the battery using the spudger
  3. Motorola Triumph Speaker Replacement, Speakers: adım 3, 1 resimden 1.
    • After removing the Battery remove the two screws with a T4 screwdriver.
  4. Motorola Triumph Speaker Replacement: adım 4, 1 resimden 1.
    • With the spudger, go around the seam of the phone and pry away the back chassis.
  5. Motorola Triumph Speaker Replacement: adım 5, 1 resimden 1.
    • Using the T5 screwdriver, remove all the four screws shown in the picture.
  6. Motorola Triumph Speaker Replacement: adım 6, 1 resimden 1.
    • Lift up the motherboard out of the device,
  7. Motorola Triumph Speaker Replacement: adım 7, 1 resimden 1.
    • Pry the speakers out using the plastic spudger.
Sonuç
greg
12 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-5, Leahy Fall 2014 USF Tampa, Team 7-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 205
