Giriş
The Motorola v180 is a flip phone with a front screen and a main LED display. It is small and compact, and has a 820 mAh lithium ion battery that lasts 5.8 hours during full media use.
This guide will cover the steps required to safely remove the battery unit on a Motorola V180. Before using this guide, it is recommended to review the Motorola v180 manual to understand more about the battery use, installing and charging of the battery unit.
Before replacing the battery unit, make sure to power off the phone completely and disconnect it from any external power source. Also, it is strongly recommended to use only Motorola original batteries in order to not cause any damage to the phone.
Completely power off the Motorola V180.
Flip the phone over to its back side.
Press down the button and slide off the back cover.
Remove the old battery.
