Ana içeriğe geç
Motorola V180 Connector Ribbon Replacement
Neye ihtiyacın var
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: adım 1, 1 resimden 1.
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: adım 2, 1 resimden 1.
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: adım 3, 1 resimden 1.
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: adım 4, 1 resimden 1.
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: adım 5, 1 resimden 1.
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: adım 6, 1 resimden 1.
    • Use a soldering iron to detach the connector ribbon from the phone.
Sonuç
Tyler Knisley
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G16
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 16
Her zaman: 2,628
