Giriş
Replacing the screen and connector ribbon.
Neye ihtiyacın var
Gently tug on the upper edge of the faceplate, and it will easily detach.
Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
Remove the SIM card located on the back of the phone.
Power off the Motorola V180.
Flip the phone over to its back side.
Hold down the button and slide off the back cover.
Remove the battery.
Now that the ribbon is loose, the screen (white part) can swing away.
Some of the black "tape" can be peeled back, but the screen is still attached. More work may be required to fully separate this part.
