Ana içeriğe geç
Motorola V180 Motherboard Replacement
Neye ihtiyacın var
  1. Motorola V180 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Motorola V180 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Motorola V180 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Motorola V180 Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Motorola V180 Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: adım 3, 2 resimden 1. Motorola V180 Motherboard Replacement: adım 3, 2 resimden 2.
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Sonuç
Tyler Knisley
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G16
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 1,562
