Ana içeriğe geç
Motorola V190 Keypad Replacement
Neye ihtiyacın var
  1. Motorola V190 Keypad Replacement, Antenna: adım 1, 2 resimden 1. Motorola V190 Keypad Replacement, Antenna: adım 1, 2 resimden 2.
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V190 Keypad Replacement, Battery: adım 2, 2 resimden 1. Motorola V190 Keypad Replacement, Battery: adım 2, 2 resimden 2.
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V190 Keypad Replacement, Mini-USB Port/Motherboard: adım 3, 1 resimden 1.
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V190 Keypad Replacement: adım 4, 3 resimden 1. Motorola V190 Keypad Replacement: adım 4, 3 resimden 2. Motorola V190 Keypad Replacement: adım 4, 3 resimden 3.
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V190 Keypad Replacement: adım 5, 3 resimden 1. Motorola V190 Keypad Replacement: adım 5, 3 resimden 2. Motorola V190 Keypad Replacement: adım 5, 3 resimden 3.
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V190 Keypad Replacement, Keypad: adım 6, 3 resimden 1. Motorola V190 Keypad Replacement, Keypad: adım 6, 3 resimden 2. Motorola V190 Keypad Replacement, Keypad: adım 6, 3 resimden 3.
    • Reopen the phone.
    • Press the push buttons (the volume buttons) through the phone frame to fully remove the keypad.
    • Push the keypad through the keypad frame.
    • Remove the keypad by lifting it over the screw holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 535
