Ana içeriğe geç
Motorola V2397 Motherboard/Screen Replacement
Neye ihtiyacın var
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: adım 1, 3 resimden 1. Motorola V2397 Motherboard/Screen Replacement, Battery: adım 1, 3 resimden 2. Motorola V2397 Motherboard/Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: adım 2, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement: adım 2, 2 resimden 2.
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: adım 3, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement, Back Cover: adım 3, 2 resimden 2.
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: adım 4, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement: adım 4, 2 resimden 2.
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: adım 5, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement, Phone: adım 5, 2 resimden 2.
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: adım 6, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: adım 6, 2 resimden 2.
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: adım 7, 2 resimden 1. Motorola V2397 Motherboard/Screen Replacement: adım 7, 2 resimden 2.
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
Sonuç
Chris
501 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Winter 2015 USF Tampa, Team 1-6, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G6
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 147
