Ana içeriğe geç
Motorola V276 Battery Replacement
Neye ihtiyacın var
  1. Motorola V276 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V276 Battery Replacement: adım 2, 1 resimden 1.
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V276 Battery Replacement: adım 3, 2 resimden 1. Motorola V276 Battery Replacement: adım 3, 2 resimden 2.
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jason Kilroy
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G96
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 2,054
