Ana içeriğe geç
Motorola V276 Keypad Replacement
Neye ihtiyacın var
  1. Motorola V276 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V276 Keypad Replacement: adım 2, 1 resimden 1.
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V276 Keypad Replacement: adım 3, 2 resimden 1. Motorola V276 Keypad Replacement: adım 3, 2 resimden 2.
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V276 Keypad Replacement, Motherboard: adım 4, 1 resimden 1.
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V276 Keypad Replacement: adım 5, 1 resimden 1.
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V276 Keypad Replacement: adım 6, 3 resimden 1. Motorola V276 Keypad Replacement: adım 6, 3 resimden 2. Motorola V276 Keypad Replacement: adım 6, 3 resimden 3.
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V276 Keypad Replacement: adım 7, 3 resimden 1. Motorola V276 Keypad Replacement: adım 7, 3 resimden 2. Motorola V276 Keypad Replacement: adım 7, 3 resimden 3.
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
    FixBot'a Sor
    Yorum Ekle
  8. Motorola V276 Keypad Replacement: adım 8, 1 resimden 1.
    • Gently peel back the motherboard from the main part of the phone.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola V276 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
    • Peel back keypad starting from the top of the phone
    • You can clean or replace the keypad once you have removed it from the phone
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Jonathan Cheung
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G96
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,213
