Ana içeriğe geç
Motorola V276 Small LCD Display Screen Replacement
Neye ihtiyacın var
  1. Motorola V276 Small LCD Display Screen Replacement, Front panel/ Screen Logic Board: adım 1, 1 resimden 1.
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Motorola V276 Small LCD Display Screen Replacement: adım 2, 1 resimden 1.
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Motorola V276 Small LCD Display Screen Replacement: adım 3, 1 resimden 1.
    • Remove silver plate from phone.
  4. Motorola V276 Small LCD Display Screen Replacement: adım 4, 1 resimden 1.
    • Using the spudger remove the plastic camera casing
  5. Motorola V276 Small LCD Display Screen Replacement: adım 5, 1 resimden 1.
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Motorola V276 Small LCD Display Screen Replacement: adım 6, 1 resimden 1.
    • Use Spudger or hands to detach flex cable from front screen logic board
  7. Motorola V276 Small LCD Display Screen Replacement, Small LCD Display Screen: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
  8. Motorola V276 Small LCD Display Screen Replacement: adım 8, 1 resimden 1.
    • Using your fingers, carefully pull out the small LCD display screen.
  9. Motorola V276 Small LCD Display Screen Replacement: adım 9, 1 resimden 1.
    • Remove the small LCD display screen completely from the green logic board.
Sonuç
Cecilia
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G96
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,797
