Ana içeriğe geç
Motorola V325 External Casing Replacement
Neye ihtiyacın var
  1. Motorola V325 External Casing Replacement, External Casing: adım 1, 3 resimden 1. Motorola V325 External Casing Replacement, External Casing: adım 1, 3 resimden 2. Motorola V325 External Casing Replacement, External Casing: adım 1, 3 resimden 3.
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 External Casing Replacement: adım 2, 3 resimden 1. Motorola V325 External Casing Replacement: adım 2, 3 resimden 2. Motorola V325 External Casing Replacement: adım 2, 3 resimden 3.
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 External Casing Replacement: adım 3, 2 resimden 1. Motorola V325 External Casing Replacement: adım 3, 2 resimden 2.
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 External Casing Replacement: adım 4, 3 resimden 1. Motorola V325 External Casing Replacement: adım 4, 3 resimden 2. Motorola V325 External Casing Replacement: adım 4, 3 resimden 3.
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
Sonuç
Minh Tran
2 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G15
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,088
