Ana içeriğe geç
Motorola V551 Keypad Key Replacement
Neye ihtiyacın var
  1. Motorola V551 Keypad Key Replacement, Battery: adım 1, 2 resimden 1. Motorola V551 Keypad Key Replacement, Battery: adım 1, 2 resimden 2.
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V551 Keypad Key Replacement: adım 2, 1 resimden 1.
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V551 Keypad Key Replacement, Circuit Board: adım 3, 3 resimden 1. Motorola V551 Keypad Key Replacement, Circuit Board: adım 3, 3 resimden 2. Motorola V551 Keypad Key Replacement, Circuit Board: adım 3, 3 resimden 3.
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V551 Keypad Key Replacement: adım 4, 1 resimden 1.
    • Unscrew the antenna.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V551 Keypad Key Replacement: adım 5, 3 resimden 1. Motorola V551 Keypad Key Replacement: adım 5, 3 resimden 2. Motorola V551 Keypad Key Replacement: adım 5, 3 resimden 3.
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V551 Keypad Key Replacement: adım 6, 2 resimden 1. Motorola V551 Keypad Key Replacement: adım 6, 2 resimden 2.
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V551 Keypad Key Replacement: adım 7, 3 resimden 1. Motorola V551 Keypad Key Replacement: adım 7, 3 resimden 2. Motorola V551 Keypad Key Replacement: adım 7, 3 resimden 3.
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola V551 Keypad Key Replacement, Keypad: adım 8, 3 resimden 1. Motorola V551 Keypad Key Replacement, Keypad: adım 8, 3 resimden 2. Motorola V551 Keypad Key Replacement, Keypad: adım 8, 3 resimden 3.
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola V551 Keypad Key Replacement, Keypad Key: adım 9, 2 resimden 1. Motorola V551 Keypad Key Replacement, Keypad Key: adım 9, 2 resimden 2.
    • Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
    • Be careful while applying the super glue as it can be quite strong.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola V551 Keypad Key Replacement: adım 10, 2 resimden 1. Motorola V551 Keypad Key Replacement: adım 10, 2 resimden 2.
    • Carefully place key onto the key pad so that it will be properly oriented and in line with the other keys.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
gregatron
105 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-6, Maness Fall 2009 Cal Poly, Team 6-6, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G6
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 2,364
