Ana içeriğe geç
Motorola V551 Keypad Replacement
Neye ihtiyacın var
  1. Motorola V551 Keypad Replacement, Battery: adım 1, 2 resimden 1. Motorola V551 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Replacement: adım 2, 1 resimden 1.
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Replacement, Circuit Board: adım 3, 3 resimden 1. Motorola V551 Keypad Replacement, Circuit Board: adım 3, 3 resimden 2. Motorola V551 Keypad Replacement, Circuit Board: adım 3, 3 resimden 3.
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Replacement: adım 4, 1 resimden 1.
    • Unscrew the antenna.
  5. Motorola V551 Keypad Replacement: adım 5, 3 resimden 1. Motorola V551 Keypad Replacement: adım 5, 3 resimden 2. Motorola V551 Keypad Replacement: adım 5, 3 resimden 3.
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Replacement: adım 6, 2 resimden 1. Motorola V551 Keypad Replacement: adım 6, 2 resimden 2.
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Replacement: adım 7, 3 resimden 1. Motorola V551 Keypad Replacement: adım 7, 3 resimden 2. Motorola V551 Keypad Replacement: adım 7, 3 resimden 3.
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Replacement, Keypad: adım 8, 3 resimden 1. Motorola V551 Keypad Replacement, Keypad: adım 8, 3 resimden 2. Motorola V551 Keypad Replacement, Keypad: adım 8, 3 resimden 3.
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
gregatron
105 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-6, Maness Fall 2009 Cal Poly, Team 6-6, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,061
