Giriş
This guide is for the purpose of replacing the headphone jack on a Motorola V557 cellphone.
Neye ihtiyacın var
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Push the metal slider towards the top of the phone until it clicks out of the original position.
Gently slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Using the push pin, gently pry the top two screws of the cover off.
The cover in the upper left of the back plate does not need to be removed.
Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
Insert the new headphone jack assembly and repeat these steps in reverse order.
