Ana içeriğe geç
Motorola V557 Rear Casing Replacement
Neye ihtiyacın var
  1. Motorola V557 Rear Casing Replacement, Battery: adım 1, 3 resimden 1. Motorola V557 Rear Casing Replacement, Battery: adım 1, 3 resimden 2. Motorola V557 Rear Casing Replacement, Battery: adım 1, 3 resimden 3.
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V557 Rear Casing Replacement: adım 2, 2 resimden 1. Motorola V557 Rear Casing Replacement: adım 2, 2 resimden 2.
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V557 Rear Casing Replacement, SIM Card: adım 3, 3 resimden 1. Motorola V557 Rear Casing Replacement, SIM Card: adım 3, 3 resimden 2. Motorola V557 Rear Casing Replacement, SIM Card: adım 3, 3 resimden 3.
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V557 Rear Casing Replacement, Antenna: adım 4, 2 resimden 1. Motorola V557 Rear Casing Replacement, Antenna: adım 4, 2 resimden 2.
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V557 Rear Casing Replacement, Rear Casing: adım 5, 3 resimden 1. Motorola V557 Rear Casing Replacement, Rear Casing: adım 5, 3 resimden 2. Motorola V557 Rear Casing Replacement, Rear Casing: adım 5, 3 resimden 3.
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V557 Rear Casing Replacement: adım 6, 3 resimden 1. Motorola V557 Rear Casing Replacement: adım 6, 3 resimden 2. Motorola V557 Rear Casing Replacement: adım 6, 3 resimden 3.
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V557 Rear Casing Replacement: adım 7, 3 resimden 1. Motorola V557 Rear Casing Replacement: adım 7, 3 resimden 2. Motorola V557 Rear Casing Replacement: adım 7, 3 resimden 3.
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alex Georges
40 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G50
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 1,783
