Ana içeriğe geç
Motorola V557 Screen Replacement
Neye ihtiyacın var
  1. Motorola V557 Screen Replacement, Faceplate: adım 1, 3 resimden 1. Motorola V557 Screen Replacement, Faceplate: adım 1, 3 resimden 2. Motorola V557 Screen Replacement, Faceplate: adım 1, 3 resimden 3.
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V557 Screen Replacement: adım 2, 2 resimden 1. Motorola V557 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 3.8 mm T-6 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V557 Screen Replacement: adım 3, 2 resimden 1. Motorola V557 Screen Replacement: adım 3, 2 resimden 2.
    • Separate the cover from the edges using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V557 Screen Replacement: adım 4, 2 resimden 1. Motorola V557 Screen Replacement: adım 4, 2 resimden 2.
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V557 Screen Replacement, Camera: adım 5, 1 resimden 1.
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V557 Screen Replacement: adım 6, 2 resimden 1. Motorola V557 Screen Replacement: adım 6, 2 resimden 2.
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V557 Screen Replacement: adım 7, 2 resimden 1. Motorola V557 Screen Replacement: adım 7, 2 resimden 2.
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola V557 Screen Replacement: adım 8, 2 resimden 1. Motorola V557 Screen Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola V557 Screen Replacement: adım 9, 3 resimden 1. Motorola V557 Screen Replacement: adım 9, 3 resimden 2. Motorola V557 Screen Replacement: adım 9, 3 resimden 3.
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola V557 Screen Replacement: adım 10, 2 resimden 1. Motorola V557 Screen Replacement: adım 10, 2 resimden 2.
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola V557 Screen Replacement, Screen: adım 11, 3 resimden 1. Motorola V557 Screen Replacement, Screen: adım 11, 3 resimden 2. Motorola V557 Screen Replacement, Screen: adım 11, 3 resimden 3.
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Blair Frandeen
19 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G50
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 3,138
