Ana içeriğe geç
Giriş
How to replace a faulty antenna.
  1. Depress the silver button. Pull from top of phone to lift the cover.
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Hold battery from both sides at the bottom. Push upwards and gently lift to remove.
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. PC Laptop Batteries
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Hemen Alışveriş Yapın
    PC Laptop Batteries
  4. Remove the four screws from the corners using a T-6 screwdriver.
    • Remove the four screws from the corners using a T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  5. Use spudger to pry up back cover from the two side clips. NOTE: sticker might be attached to rest of phone.
    • Use spudger to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  6. Flip over the back cover. Remove the plastic frame. Remove the plastic frame.
    • Flip over the back cover.
    • Remove the plastic frame.
  7. Lift up antenna. Lift up antenna.
    • Lift up antenna.
Sonuç
Ryan Kuroiwa
1 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G86
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,698
