Giriş
How to replace the logic board.
  1. Depress the silver button.
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Hold battery from both sides at the bottom.
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
    • Remove the back cover.
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
Sonuç
Ryan Kuroiwa
1 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G86
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 2,245
