Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Step-by-step guide to removing your phone's antenna.
  1. The antenna is located on top right corner of the phone while the front of the phone is facing you. Unscrew the antenna clockwise until it is loose enough to remove from the phone. Unscrew the antenna clockwise until it is loose enough to remove from the phone.
    • The antenna is located on top right corner of the phone while the front of the phone is facing you.
    • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth OBrien
43 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G40
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 3,097
