Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will cover the steps on how to remove the back plate of a Motorola V60i.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the phone over so the back cover is facing up. Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Pry up the back plate from the phone. Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  4. Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  5. Simultaneously press the highlighted buttons on both sides of phone. Simultaneously press the highlighted buttons on both sides of phone.
    • Simultaneously press the highlighted buttons on both sides of phone.
  6. Separate the back plate from the rest of phone.
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
Sonuç
Elizabeth OBrien
43 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G40
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 3,314
