Ana içeriğe geç
Motorola V60s Button Key Pad Replacement
Neye ihtiyacın var
  1. Motorola V60s Button Key Pad Replacement, Battery: adım 1, 3 resimden 1. Motorola V60s Button Key Pad Replacement, Battery: adım 1, 3 resimden 2. Motorola V60s Button Key Pad Replacement, Battery: adım 1, 3 resimden 3.
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V60s Button Key Pad Replacement: adım 2, 2 resimden 1. Motorola V60s Button Key Pad Replacement: adım 2, 2 resimden 2.
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V60s Button Key Pad Replacement, Motherboard: adım 3, 2 resimden 1. Motorola V60s Button Key Pad Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V60s Button Key Pad Replacement: adım 4, 3 resimden 1. Motorola V60s Button Key Pad Replacement: adım 4, 3 resimden 2. Motorola V60s Button Key Pad Replacement: adım 4, 3 resimden 3.
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V60s Button Key Pad Replacement: adım 5, 3 resimden 1. Motorola V60s Button Key Pad Replacement: adım 5, 3 resimden 2. Motorola V60s Button Key Pad Replacement: adım 5, 3 resimden 3.
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V60s Button Key Pad Replacement: adım 6, 3 resimden 1. Motorola V60s Button Key Pad Replacement: adım 6, 3 resimden 2. Motorola V60s Button Key Pad Replacement: adım 6, 3 resimden 3.
    • Gently remove orange ribbon cable by prying up with spudger.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V60s Button Key Pad Replacement: adım 7, 2 resimden 1. Motorola V60s Button Key Pad Replacement: adım 7, 2 resimden 2.
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: adım 8, 2 resimden 1. Motorola V60s Button Key Pad Replacement, Button Key Board: adım 8, 2 resimden 2.
    • Insert an opening tool under the button board and gently lift.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: adım 9, 2 resimden 1. Motorola V60s Button Key Pad Replacement, Button Key Pad: adım 9, 2 resimden 2.
    • Life button keypad with spudger and set aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eric Freeman
12 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G48
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 3,315
