Giriş
This guide shows how to take apart the front casing. This allows access to the front LCD screen.
  1. Push in and hold small release latch.
    • Push in and hold small release latch.
    • Hold the latch through step 2.
  2. While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover.
    • While holding the release latch, use a opening tool to help you slide off the front cover.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the two Philips screws at top of phone with a #1 Philips screwdriver. Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
    • Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
  5. Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display.
    • Use a opening tool to gently pry off black cover, revealing the internal LCD display.
Sonuç
Eric Freeman
1 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G48
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 2,177
