Ana içeriğe geç
Motorola V60s Logic Board Replacement
Neye ihtiyacın var
  1. Motorola V60s Logic Board Replacement, Battery: adım 1, 3 resimden 1. Motorola V60s Logic Board Replacement, Battery: adım 1, 3 resimden 2. Motorola V60s Logic Board Replacement, Battery: adım 1, 3 resimden 3.
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Logic Board Replacement: adım 2, 2 resimden 1. Motorola V60s Logic Board Replacement: adım 2, 2 resimden 2.
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Logic Board Replacement, Logic Board: adım 3, 2 resimden 1. Motorola V60s Logic Board Replacement, Logic Board: adım 3, 2 resimden 2.
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Logic Board Replacement: adım 4, 3 resimden 1. Motorola V60s Logic Board Replacement: adım 4, 3 resimden 2. Motorola V60s Logic Board Replacement: adım 4, 3 resimden 3.
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Logic Board Replacement: adım 5, 3 resimden 1. Motorola V60s Logic Board Replacement: adım 5, 3 resimden 2. Motorola V60s Logic Board Replacement: adım 5, 3 resimden 3.
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Logic Board Replacement: adım 6, 3 resimden 1. Motorola V60s Logic Board Replacement: adım 6, 3 resimden 2. Motorola V60s Logic Board Replacement: adım 6, 3 resimden 3.
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Logic Board Replacement: adım 7, 2 resimden 1. Motorola V60s Logic Board Replacement: adım 7, 2 resimden 2.
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Freeman
10 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G48
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,867
