Ana içeriğe geç
Motorola V60s Speakers Replacement
Neye ihtiyacın var
  1. Motorola V60s Speakers Replacement, Battery: adım 1, 3 resimden 1. Motorola V60s Speakers Replacement, Battery: adım 1, 3 resimden 2. Motorola V60s Speakers Replacement, Battery: adım 1, 3 resimden 3.
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: adım 2, 2 resimden 1. Motorola V60s Speakers Replacement: adım 2, 2 resimden 2.
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: adım 3, 2 resimden 1. Motorola V60s Speakers Replacement, Speakers: adım 3, 2 resimden 2.
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: adım 4, 2 resimden 1. Motorola V60s Speakers Replacement: adım 4, 2 resimden 2.
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: adım 5, 1 resimden 1.
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Sonuç
Eric Freeman
10 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G48
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,553
