Ana içeriğe geç
Motorola V710 Keyboard Replacement
Neye ihtiyacın var
  1. Motorola V710 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Motorola V710 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Motorola V710 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V710 Keyboard Replacement: adım 2, 3 resimden 1. Motorola V710 Keyboard Replacement: adım 2, 3 resimden 2. Motorola V710 Keyboard Replacement: adım 2, 3 resimden 3.
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V710 Keyboard Replacement, Keypad: adım 3, 1 resimden 1.
    • Unscrew the antenna with a clockwise motion and pull to remove the antenna.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V710 Keyboard Replacement: adım 4, 2 resimden 1. Motorola V710 Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V710 Keyboard Replacement: adım 5, 2 resimden 1. Motorola V710 Keyboard Replacement: adım 5, 2 resimden 2.
    • Use the spudger to remove the bottom plate.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V710 Keyboard Replacement: adım 6, 2 resimden 1. Motorola V710 Keyboard Replacement: adım 6, 2 resimden 2.
    • Unscrew the bottom two screws with the T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola V710 Keyboard Replacement: adım 7, 2 resimden 1. Motorola V710 Keyboard Replacement: adım 7, 2 resimden 2.
    • Use the spudger to remove the keyboard plate.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola V710 Keyboard Replacement: adım 8, 1 resimden 1.
    • Use your fingers to push out the keyboard.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Karl Sanders
8 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G49
5 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 2,239
