Ana içeriğe geç
Motorola V710 LCD screen replacement
Neye ihtiyacın var
  1. Motorola V710 LCD screen replacement, Screen: adım 1, 3 resimden 1. Motorola V710 LCD screen replacement, Screen: adım 1, 3 resimden 2. Motorola V710 LCD screen replacement, Screen: adım 1, 3 resimden 3.
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola V710 LCD screen replacement: adım 2, 2 resimden 1. Motorola V710 LCD screen replacement: adım 2, 2 resimden 2.
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola V710 LCD screen replacement: adım 3, 2 resimden 1. Motorola V710 LCD screen replacement: adım 3, 2 resimden 2.
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola V710 LCD screen replacement: adım 4, 2 resimden 1. Motorola V710 LCD screen replacement: adım 4, 2 resimden 2.
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola V710 LCD screen replacement: adım 5, 2 resimden 1. Motorola V710 LCD screen replacement: adım 5, 2 resimden 2.
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola V710 LCD screen replacement: adım 6, 2 resimden 1. Motorola V710 LCD screen replacement: adım 6, 2 resimden 2.
    • Use the spudger to remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Onnen
11 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G49
5 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 2,392
