Ana içeriğe geç
Motorola V710 Logic Board Replacement
Neye ihtiyacın var
  1. Motorola V710 Logic Board Replacement, Battery: adım 1, 3 resimden 1. Motorola V710 Logic Board Replacement, Battery: adım 1, 3 resimden 2. Motorola V710 Logic Board Replacement, Battery: adım 1, 3 resimden 3.
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Logic Board Replacement: adım 2, 3 resimden 1. Motorola V710 Logic Board Replacement: adım 2, 3 resimden 2. Motorola V710 Logic Board Replacement: adım 2, 3 resimden 3.
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Logic Board Replacement, Logic Board: adım 3, 2 resimden 1. Motorola V710 Logic Board Replacement, Logic Board: adım 3, 2 resimden 2.
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Logic Board Replacement: adım 4, 2 resimden 1. Motorola V710 Logic Board Replacement: adım 4, 2 resimden 2.
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Logic Board Replacement: adım 5, 3 resimden 1. Motorola V710 Logic Board Replacement: adım 5, 3 resimden 2. Motorola V710 Logic Board Replacement: adım 5, 3 resimden 3.
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Logic Board Replacement: adım 6, 2 resimden 1. Motorola V710 Logic Board Replacement: adım 6, 2 resimden 2.
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Logic Board Replacement: adım 7, 2 resimden 1. Motorola V710 Logic Board Replacement: adım 7, 2 resimden 2.
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Logic Board Replacement: adım 8, 3 resimden 1. Motorola V710 Logic Board Replacement: adım 8, 3 resimden 2. Motorola V710 Logic Board Replacement: adım 8, 3 resimden 3.
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Logic Board Replacement: adım 9, 1 resimden 1.
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Logic Board Replacement: adım 10, 2 resimden 1. Motorola V710 Logic Board Replacement: adım 10, 2 resimden 2.
    • Remove the logic board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Karl Sanders
8 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G49
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,996
