Ana içeriğe geç
Motorola V710 Vibrating Motor Replacement
Neye ihtiyacın var
  1. Motorola V710 Vibrating Motor Replacement, Screen: adım 1, 3 resimden 1. Motorola V710 Vibrating Motor Replacement, Screen: adım 1, 3 resimden 2. Motorola V710 Vibrating Motor Replacement, Screen: adım 1, 3 resimden 3.
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 Vibrating Motor Replacement: adım 2, 2 resimden 1. Motorola V710 Vibrating Motor Replacement: adım 2, 2 resimden 2.
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 Vibrating Motor Replacement: adım 3, 2 resimden 1. Motorola V710 Vibrating Motor Replacement: adım 3, 2 resimden 2.
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 Vibrating Motor Replacement: adım 4, 2 resimden 1. Motorola V710 Vibrating Motor Replacement: adım 4, 2 resimden 2.
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 Vibrating Motor Replacement: adım 5, 2 resimden 1. Motorola V710 Vibrating Motor Replacement: adım 5, 2 resimden 2.
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 Vibrating Motor Replacement: adım 6, 2 resimden 1. Motorola V710 Vibrating Motor Replacement: adım 6, 2 resimden 2.
    • Use the spudger to remove the screen.
  7. Motorola V710 Vibrating Motor Replacement, Vibrating Motor: adım 7, 2 resimden 1. Motorola V710 Vibrating Motor Replacement, Vibrating Motor: adım 7, 2 resimden 2.
    • Remove the vibrating motor from the phone with the spudger.
Sonuç
Karl Sanders
8 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G49
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,662
