Ana içeriğe geç
Motorola W315 Antenna Replacement
Neye ihtiyacın var
  1. Motorola W315 Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Antenna Replacement: adım 3, 1 resimden 1.
    • Insert the new battery.
  3. Motorola W315 Antenna Replacement, Rear Case: adım 4, 1 resimden 1.
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Antenna Replacement: adım 5, 3 resimden 1. Motorola W315 Antenna Replacement: adım 5, 3 resimden 2. Motorola W315 Antenna Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Antenna Replacement, Antenna: adım 6, 1 resimden 1.
    • Gently twist the antenna in a counter-clockwise direction to unscrew it.
  6. Motorola W315 Antenna Replacement: adım 7, 2 resimden 1. Motorola W315 Antenna Replacement: adım 7, 2 resimden 2.
    • Pull the antenna out through the hole in the top of the frame and set it aside.
  7. Motorola W315 Antenna Replacement: adım 8, 3 resimden 1. Motorola W315 Antenna Replacement: adım 8, 3 resimden 2. Motorola W315 Antenna Replacement: adım 8, 3 resimden 3.
    • Using a plastic opening tool, lift and remove the antenna casing.
Sonuç
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G3
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 217
