Ana içeriğe geç
Motorola W385 Front Casing Replacement
Neye ihtiyacın var
  1. Motorola W385 Front Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Front Casing Replacement: adım 2, 1 resimden 1.
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Front Casing Replacement, Front Casing: adım 3, 1 resimden 1.
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Front Casing Replacement: adım 4, 1 resimden 1.
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Front Casing Replacement: adım 5, 2 resimden 1. Motorola W385 Front Casing Replacement: adım 5, 2 resimden 2.
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Front Casing Replacement: adım 6, 1 resimden 1.
    • If the casing has not popped off of the body, remove it carefully from the the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Hobbs
69 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G50
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 1,929
