Neye ihtiyacın var
Pick up the cell phone with the back facing towards you.
Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
Set the battery aside.
After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
Remove all the screws using the Torx T6 Screwdriver.
Identify the flex cable attachment. Indicated in a red square.
Detach the bottom half of the flex cable, pop it off of the circuit board.
Pick up the loosened circuit board from the phone and set aside.
2 farklı kişi bu kılavuzu tamamladı.
