Ana içeriğe geç
Motorola W490 Flex Cable Replacement
Neye ihtiyacın var
    1. Motorola W490 Flex Cable Replacement, Phone Casing: adım 1, 2 resimden 1. Motorola W490 Flex Cable Replacement, Phone Casing: adım 1, 2 resimden 2.
      • Pick up the cell phone with the back facing towards you.
      • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
      • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, Battery: adım 2, 2 resimden 1. Motorola W490 Flex Cable Replacement, Battery: adım 2, 2 resimden 2.
      • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
      • Set the battery aside.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, Lower Metal Frame: adım 3, 2 resimden 1. Motorola W490 Flex Cable Replacement, Lower Metal Frame: adım 3, 2 resimden 2.
      • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
      • Remove all the screws using the Torx T6 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola W490 Flex Cable Replacement: adım 4, 3 resimden 1. Motorola W490 Flex Cable Replacement: adım 4, 3 resimden 2. Motorola W490 Flex Cable Replacement: adım 4, 3 resimden 3.
      • Turn over the phone to the front side and open up the phone, displaying the keypad.
      • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
      • Pull and set the glued plastic cover aside.
      • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola W490 Flex Cable Replacement: adım 5, 2 resimden 1. Motorola W490 Flex Cable Replacement: adım 5, 2 resimden 2.
      • Under the plastic cover, locate two star-shaped T5 screws.
      • Use the Torx T5 Screwdriver to remove the two screws.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola W490 Flex Cable Replacement: adım 6, 3 resimden 1. Motorola W490 Flex Cable Replacement: adım 6, 3 resimden 2. Motorola W490 Flex Cable Replacement: adım 6, 3 resimden 3.
      • Turn over the phone to the back side of phone where the battery was removed.
      • Use hands to remove the unscrewed rear frame of the phone.
      • Set aside the rear metal frame.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, Circuit Board: adım 7, 3 resimden 1. Motorola W490 Flex Cable Replacement, Circuit Board: adım 7, 3 resimden 2. Motorola W490 Flex Cable Replacement, Circuit Board: adım 7, 3 resimden 3.
      • Identify the flex cable attachment. Indicated in a red square.
      • Detach the bottom half of the flex cable, pop it off of the circuit board.
      • Pick up the loosened circuit board from the phone and set aside.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, Upper Metal Frame: adım 8, 2 resimden 1. Motorola W490 Flex Cable Replacement, Upper Metal Frame: adım 8, 2 resimden 2.
      • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
      • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola W490 Flex Cable Replacement: adım 9, 3 resimden 1. Motorola W490 Flex Cable Replacement: adım 9, 3 resimden 2. Motorola W490 Flex Cable Replacement: adım 9, 3 resimden 3.
      • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola W490 Flex Cable Replacement: adım 10, 2 resimden 1. Motorola W490 Flex Cable Replacement: adım 10, 2 resimden 2.
      • Pull the flex cable connection away from the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola W490 Flex Cable Replacement: adım 11, 2 resimden 1. Motorola W490 Flex Cable Replacement: adım 11, 2 resimden 2.
      • Pull the camera connection away from the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola W490 Flex Cable Replacement: adım 12, 3 resimden 1. Motorola W490 Flex Cable Replacement: adım 12, 3 resimden 2. Motorola W490 Flex Cable Replacement: adım 12, 3 resimden 3.
      • Pull the upper metal frame away from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, LCD Screen: adım 13, 3 resimden 1. Motorola W490 Flex Cable Replacement, LCD Screen: adım 13, 3 resimden 2. Motorola W490 Flex Cable Replacement, LCD Screen: adım 13, 3 resimden 3.
      • Hold the outer phone casing and pull the LCD screen out.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola W490 Flex Cable Replacement, Flex Cable: adım 14, 2 resimden 1. Motorola W490 Flex Cable Replacement, Flex Cable: adım 14, 2 resimden 2.
      • Remove the other end of the flex cable from the LCD board.
      • Pull the cable through the phone casing hinge and remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Will Edwards
61 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G1
4 Üyeler
84 adet Kılavuz yazıldı
2Kılavuz Yorumları
How the !@#$ do you get the new flex cable in??? Id about anybody else, but mine was snapped in half when I opened it, thus, I was unable to see the original assembly... HELP???? Please??
Angela WM - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 1,373
