Ana içeriğe geç
Motorola W490 LCD Screen Replacement
Neye ihtiyacın var
  1. Motorola W490 LCD Screen Replacement, Upper Metal Frame: adım 1, 2 resimden 1. Motorola W490 LCD Screen Replacement, Upper Metal Frame: adım 1, 2 resimden 2.
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Motorola W490 LCD Screen Replacement: adım 2, 3 resimden 1. Motorola W490 LCD Screen Replacement: adım 2, 3 resimden 2. Motorola W490 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. Motorola W490 LCD Screen Replacement: adım 3, 2 resimden 1. Motorola W490 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Pull the flex cable connection away from the top of the phone.
  4. Motorola W490 LCD Screen Replacement: adım 4, 2 resimden 1. Motorola W490 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Pull the camera connection away from the top of the phone.
  5. Motorola W490 LCD Screen Replacement: adım 5, 3 resimden 1. Motorola W490 LCD Screen Replacement: adım 5, 3 resimden 2. Motorola W490 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Pull the upper metal frame away from the phone.
  6. Motorola W490 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 1. Motorola W490 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 2. Motorola W490 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 3.
    • Hold the outer phone casing and pull the LCD screen out.
Sonuç
Will Edwards
61 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G1
4 Üyeler
23 adet Kılavuz yazıldı
1Rehber Yorum
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 611
