Ana içeriğe geç
Motorola W490 Lower Metal Frame Replacement
Neye ihtiyacın var
  1. Motorola W490 Lower Metal Frame Replacement, Phone Casing: adım 1, 2 resimden 1. Motorola W490 Lower Metal Frame Replacement, Phone Casing: adım 1, 2 resimden 2.
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Lower Metal Frame Replacement, Battery: adım 2, 2 resimden 1. Motorola W490 Lower Metal Frame Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 Lower Metal Frame Replacement, Lower Metal Frame: adım 3, 2 resimden 1. Motorola W490 Lower Metal Frame Replacement, Lower Metal Frame: adım 3, 2 resimden 2.
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  4. Motorola W490 Lower Metal Frame Replacement: adım 4, 3 resimden 1. Motorola W490 Lower Metal Frame Replacement: adım 4, 3 resimden 2. Motorola W490 Lower Metal Frame Replacement: adım 4, 3 resimden 3.
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  5. Motorola W490 Lower Metal Frame Replacement: adım 5, 2 resimden 1. Motorola W490 Lower Metal Frame Replacement: adım 5, 2 resimden 2.
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  6. Motorola W490 Lower Metal Frame Replacement: adım 6, 3 resimden 1. Motorola W490 Lower Metal Frame Replacement: adım 6, 3 resimden 2. Motorola W490 Lower Metal Frame Replacement: adım 6, 3 resimden 3.
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Will Edwards
61 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G1
4 Üyeler
23 adet Kılavuz yazıldı
Bir Yorum
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 438
