Ana içeriğe geç
Motorola W490 Upper Metal Frame Replacement
Neye ihtiyacın var
  1. Motorola W490 Upper Metal Frame Replacement, Upper Metal Frame: adım 1, 2 resimden 1. Motorola W490 Upper Metal Frame Replacement, Upper Metal Frame: adım 1, 2 resimden 2.
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Motorola W490 Upper Metal Frame Replacement: adım 2, 3 resimden 1. Motorola W490 Upper Metal Frame Replacement: adım 2, 3 resimden 2. Motorola W490 Upper Metal Frame Replacement: adım 2, 3 resimden 3.
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. Motorola W490 Upper Metal Frame Replacement: adım 3, 2 resimden 1. Motorola W490 Upper Metal Frame Replacement: adım 3, 2 resimden 2.
    • Pull the flex cable connection away from the top of the phone.
  4. Motorola W490 Upper Metal Frame Replacement: adım 4, 2 resimden 1. Motorola W490 Upper Metal Frame Replacement: adım 4, 2 resimden 2.
    • Pull the camera connection away from the top of the phone.
  5. Motorola W490 Upper Metal Frame Replacement: adım 5, 3 resimden 1. Motorola W490 Upper Metal Frame Replacement: adım 5, 3 resimden 2. Motorola W490 Upper Metal Frame Replacement: adım 5, 3 resimden 3.
    • Pull the upper metal frame away from the phone.
Sonuç
Hannah
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G1
4 Üyeler
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 436
