Ana içeriğe geç
Motorola Xoom 2 Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: adım 1, 3 resimden 1. Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: adım 1, 3 resimden 2. Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: adım 1, 3 resimden 3.
    • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
    FixBot'a Sor
  2. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 2, 2 resimden 1. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
    FixBot'a Sor
  3. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 3, 3 resimden 1. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 3, 3 resimden 2. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 3, 3 resimden 3.
    • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
    • There is adhesive between the back-plate and battery.
    FixBot'a Sor
  4. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the back plate from your device.
    FixBot'a Sor
  5. Motorola Xoom 2 Rear-Facing Camera Replacement, Rear-Facing Camera: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the blue Kapton tape.
    • Set this piece aside as it is required for reassembly.
    FixBot'a Sor
  6. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 6, 2 resimden 1. Motorola Xoom 2 Rear-Facing Camera Replacement: adım 6, 2 resimden 2.
    • Using a spudger, carefully pry and remove camera assembly using the small pry point as shown.
    • After removing the camera from the housing, use tweezers and pull gently to remove the connector from its housing.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 291
